Light upgrades
Light upgrades
Postby hydroshok » Sun Sep 16, 2012 4:18 pm
I don't know if this is the right place, but I have been looking for new marker/turn signal lights on the front under the headlights. Is there a website that sells clear ones or regular replacements? I found side markers on e-bay and one front replacement. Both of my fronts are cracked. Thanks!
hydroshok
Re: Light upgrades
Postby cmann250 » Sun Sep 16, 2012 4:36 pm
What year of truck are you dealing with?
Re: Light upgrades
Postby hydroshok » Sun Sep 16, 2012 4:42 pm
Sorry. Forgot I have no sig yet. Its an 89 D350. It has an 83 crew cab. I don't know if the grill that the light mounts to is 83 or 89 though. Is there any difference or a way to tell?
hydroshok
Re: Light upgrades
Postby cmann250 » Sun Sep 16, 2012 5:26 pm
My '89 has the turn signals molded into the head light buckets. I've never seen clear turn signals for the the older 1st gens. A salvage yard is a good bet for replacements
Re: Light upgrades
Postby RumbleFish » Sun Sep 16, 2012 5:43 pm
83 and 89 both have a non replaceable front turn signal lens, although they are different. The 81-85 grille hhasa bunch of squares, the 86-90 has a cross hair.
Re: Light upgrades
Postby hydroshok » Sun Sep 16, 2012 5:53 pm
I'm not sure what you mean so which one do I have?
Any suggestions to fix the cracks would be great. I hate that yellow repair tape. It looks like crap. Best bet just to find a whole grill from a junk yard?
hydroshok
Re: Light upgrades
Postby cmann250 » Sun Sep 16, 2012 6:08 pm
You have the '86-'90 grille. The plactic piece that goes around the head light and includes the turn signal is all one piece, the plastic grile is one big piece, and that aluminum trim is one big piece that goes around it all. I'd look in a salvage yard. I'm sure Dodge has some buried in a warehouse, but they likely aren't cheap
Re: Light upgrades
Postby hydroshok » Sun Sep 16, 2012 6:23 pm
Cool. Thanks! I'll check around. Glad I didn't buy that one on Ebay now...
hydroshok
Re: Light upgrades
Postby cumminz90 » Wed Sep 26, 2012 7:26 pm
http://www.autobodyspecialt.com/cgi-bin ... &key=D-28R
I'm going to try out a set of these smoked ones when i get my truck to the paint stage they look good to me.
1990 D250 sc Cummins: 175 p pumped motor: (400ccs)100 plate, 4k springs, rack plug,Jl machine 5x16 injectors, ad150, cooler tubz, hellman sump, studs, valvesprings, hx35/3b twins, timing 20 *, soon to be built 47rh
GFs: 1993 w250 cc: Normal pump mods, timing to the head, 3200 spring, denny t stage 2, DDP 4 injectors, hx 40, swapped in a rag
1991 w250 rclb: normals pump stuff 3200 spring
cumminz90
Re: Light upgrades
Postby hydroshok » Wed Sep 26, 2012 7:36 pm
Those do look good. I was going to say they are cheap too, but then I read the bottom. Thanks for the link.
89 D350 5spd 83 crew cab: waiting on new drivetrain
1999 2500 5spd: 2001 HO motor, smarty, edge comp, 40hp injectors, AFE intake, AirDog, rebuilt NV4500, HX40, full air ride
hydroshok
