2nd gen seats
2nd gen seats
Postby (92)cummins » Sun Oct 21, 2012 11:31 am
will seats out of a 98 ext cab fit in a 1st gen regular cab, i have a set of buckets laying around
92 w350 srw flatbed
1985 D350 crew cab diesel conversion in progress
79 w200 power wagon
93 D350 drw 5spd getrag 4 door donor
90 D350 auto(fried) flatbed
93 D250 auto
(92)cummins
Re: 2nd gen seats
Postby olde_blue » Tue Oct 23, 2012 5:58 am
I have buckets with a flip-down center console from an early 2nd gen in my regular cab truck. The seats fit fairly well, except for the center console. When the console is up, the lid hits the metal lip below the window, and rubs. The center backrest is almost completely upright, and you can sit on it without any greater discomfort than was originally intended, but I need to put a towel behind it to prevent scuffing and squeaking. There is a little less room behind the seats than with an original bench, but it is easier to get to, since you can fold the back of each bucket individually.
olde_blue
Re: 2nd gen seats
Postby (92)cummins » Tue Oct 23, 2012 2:04 pm
ok the ones i have are the thick ones, ill try to find early 2nd gen seats
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: 2nd gen seats
Postby Hansen01 » Thu Oct 25, 2012 5:15 pm
I have some out of the new 2nd gens with all of the problems that the previous guy said. Plus if your tall you may need to cut the seat brackets or your head and knees will hit stuff. Also have to drill new holes and make a spacer for the back bracket, not Tough and overall much better than the bench in my oppinion
Under construction...
Hansen01
Re: 2nd gen seats
Postby (92)cummins » Fri Oct 26, 2012 9:19 am
Well im short so that isn't a problem and dont really need to fit three people in my truck
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: 2nd gen seats
Postby Hansen01 » Fri Nov 02, 2012 4:01 pm
U can still fit three in if you fit it so the console will flip up strait
Hansen01
Re: 2nd gen seats
Postby (92)cummins » Fri Nov 02, 2012 6:08 pm
o i thought that metal lip wuld keep it from goin straight
92 w350 srw flatbed
79 w200 power wagon
93 D250 auto
(92)cummins
Re: 2nd gen seats
Postby PToombs » Sat Nov 03, 2012 5:33 pm
I have the 2nd gen seats in a regular cab, the center flips up plenty far enough to seat 3. I haul my kids in booster seats all the time also.
Re: 2nd gen seats
Postby ThatOld1stGen92 » Thu Nov 29, 2012 7:12 am
I have second gen seats out of an extended cab in my truck, it took a little chop, chop, weld, weld, but their in there.. however if you don't like your head in the ceiling these aren't the seats for you haha
ThatOld1stGen92
Re: 2nd gen seats
Postby PToombs » Thu Nov 29, 2012 6:18 pm
Mine aren't too high. I cut 1 inch out of the front of stock bench bases and welded them back together and it sits nice. A little higher, and not leaning back like they would have been.
Re: 2nd gen seats
Postby dunes450r » Fri Nov 30, 2012 7:32 am
i have second gen seats with the center console in mine as well. the PO put them in and i'm pretty sure they are stock height. i'm 6' and have plenty of room between my head and the ceiling. these are pretty big cabs!
dunes450r
Re: 2nd gen seats
Postby ThatOld1stGen92 » Tue Dec 04, 2012 6:51 am
I must have done something wrong then haha I'm 6' 4'' and my hat always hits the ceiling.. well the saggy headliner doesn't help!
ThatOld1stGen92
Re: 2nd gen seats
Postby cummins12club » Mon Dec 10, 2012 12:10 pm
How about putting 2nd gen ext cab rear seat in ext cab 1st Gen I've seen done pics of this and it looks cool but I wonder how functional it is?
cummins12club
Re: 2nd gen seats
Postby CumminsPower59 » Mon Dec 10, 2012 12:15 pm
It's really tight back there, not much leg room. I was going to go that route, but with the bottom of the 2nd gen Dodge rear seats being 20" deep, there would be only inches between the front of the rear seat and the backs of the front...
Re: 2nd gen seats
Postby ihredneck » Mon Dec 17, 2012 8:46 pm
now I'm interested in this!I'm 6'6" and have a set of 98.5 bucket seats to put in my regular cab. sounds like i need to shorten them at least an inch or so? Old 1st Gen, how much room between your head and the liner?
ihredneck
