Quick Question!
Quick Question!
Postby bubba » Wed Nov 14, 2012 8:52 pm
How different is my 1992 cab from 1975?
bubba
Re: Quick Question!
Postby simplysmn » Sun Nov 18, 2012 12:09 pm
What do you mean by different ? are you going to mount the 92 cab on a 75 frame ? I wanna say they will swap over
simplysmn
Re: Quick Question!
Postby oldestof11 » Sun Nov 18, 2012 12:18 pm
Before 92, iirc, the 2wd cab didnt have the hump for the 4wd selection.
Re: Quick Question!
Postby bubba » Sun Nov 18, 2012 2:51 pm
I was wondering because I had found a 1975 Club Cab half ton 2wd and I'd like to mount it on my frame.
bubba
Re: Quick Question!
Postby oldestof11 » Sun Nov 18, 2012 5:17 pm
Front fenders might be different. Ask Mark Nixon.
Re: Quick Question!
Postby dazedandconfused » Sun Nov 18, 2012 5:18 pm
Cab is pretty much the same but the fenders and doors have different body lines i believe is what Mark has said before.
Re: Quick Question!
Postby bubba » Sun Nov 18, 2012 8:29 pm
So I'd have to use the '75 fenders and grille?
bubba
Re: Quick Question!
Postby CumminsPower59 » Mon Nov 19, 2012 3:36 am
Use the 75 cab, but use your doors and front clip. The body lines that run on the newer fenders and doors stop at the back of the door and don't continue on at the club cab section, as the cabs are the same there.
Re: Quick Question!
Postby bubba » Thu Nov 29, 2012 10:44 pm
Ok thanks guys but it looks like I missed out. I had found a whole truck in Hotlanta for $600 and was gonna knock the guy down with it but it looks like it got away...
bubba
