turn signal lever broke....
Postby 1990CTD » Tue Jan 01, 2013 8:48 am
My turn signal lever/bright light switch is broke. It is broke at the base and I can't turn on the bright lights because I have a gt grant steering wheel cause the old one was junk and it hits, and I can't put on the left turn signal because it hits so I have to hold it down. Any ideas on how to fix them or rig something up. I tried to super glue it but didn't hold. Its the plastic price around the little shaft inside it, it is snapped off where at the base.
1990CTD
Re: turn signal lever broke....
Postby CumminsPower59 » Tue Jan 01, 2013 8:52 am
Replace it. It's a pretty easy job to do, couple screws on the column covers, and a couple holding the multifunction switch on, and one large flat electrical connector and you are good to go!
Postby 1990CTD » Tue Jan 01, 2013 9:53 am
Where would I get one? I wish they made a catalog for these trucks like lmc.
1990CTD
Postby dazedandconfused » Tue Jan 01, 2013 1:39 pm
Any auto parts store can get them. Here is one for a 93.
http://m.autozone.com/autozone-mobile/e ... ?id=180303
Postby 1990CTD » Tue Jan 01, 2013 3:30 pm
I don't need the whole switch. I just need the lever, it is broke. The switch works I just can't use it good because the lever is broke and rubs before it clicks.
1990CTD
Postby dazedandconfused » Tue Jan 01, 2013 3:40 pm
I don't think you can just buy that. They wear out after a while and for only $50 something dollars its a cheap part to replace.
Postby 1990CTD » Tue Jan 01, 2013 7:18 pm
Okay.
1990CTD
