New key set, doors + ignition
Postby Gots_a_sol » Thu Jan 31, 2013 1:10 pm
So I had this happen while I was out of town. Since I needed to get home, I just stuck the broken piece in the ignition so I could start the truck.
Obviously the key was pretty worn. I've been opening my doors with my jeep's key, so obviously those are worn too. I'd like to replace the door locks and ignition and only have one key for both like I did. I can't find a place to buy them as a set for our trucks.
So I guess the point of this thread is, does anybody know where I can buy a NEW matched set for our trucks?
-Joe
Gots_a_sol
Re: New key set, doors + ignition
Postby ellis93 » Thu Jan 31, 2013 4:54 pm
A locksmith can hook you up,I've had two chevys done up like the military(one key) does so I know you could buy new locks and have them keyed alike. O'Reilly has them or can get them,door locks and key tumbler
Postby Philip » Sat Feb 02, 2013 6:59 am
Take the key into any place that has a key machine. They can run a new one off that broken key. I have done it before.
Postby dazedandconfused » Sat Feb 02, 2013 9:23 am
I found them once before on line as a kit last year. Ill try yo find it again when i get to a real computer since i think i saved it on there.
Postby RumbleFish » Sat Feb 02, 2013 9:36 am
I got a complete set out of a 96ish bseries amish hauler van. Ignition cylinder was a direct swap, switch and all. The door cylinders only needed the clip changed on the back. I got a matched set for $10 at the jy.
Postby bmoeller » Sat Feb 02, 2013 12:23 pm
A drawback to using an old key as a master, is that the new ones may not work well. Especially if the person running the machine is lazy, and makes a sloppy duplicate. Been there, done that!
Would think these would work, if you have a tilt wheel.
http://www.ebay.com/itm/NEW-IGNITION-SW ... 94&vxp=mtr
SOLD- '99 3500, SO CTD, 5spd
bmoeller
