CC Conversion
CC Conversion
Postby cumminsgirl » Fri Feb 15, 2013 10:21 pm
Contemplating converting the ext cab to a crew cab. I've thought about just selling what I've got, it'd be a lot easier in the long run but since when do I ever go the easy route Lol :roll:
Anyone done this and have suggestions for me? (or more like what not to do) I love my truck, but I miss having a functional back seat and doors. While it's tore down Id like to apply some air ride as well to help smooth out the ride a bit.
1993 W350 4x4 Dually, 5spd, HX35 Turbo, M4 Fuel Pin, Fuel and smoke screw adjusted, Hydro assisted brake mod, 6" bull horn stacks.
cumminsgirl
Re: CC Conversion
Postby simplysmn » Fri Feb 15, 2013 11:52 pm
if you do this you will have to butcher the floor board on the back side unless you go with a body lift look arfound and just find you a crewcab much easier to do My truck took 16 day's to put together so it can be done fairly simple . Feel free to PM me if you want a bunch of Pick's of a Crewcab build .
simplysmn
Re: CC Conversion
Postby CumminsPower59 » Sat Feb 16, 2013 1:54 pm
Why not stretch the frame instead of chopping the floor?
Re: CC Conversion
Postby cumminsgirl » Sat Feb 16, 2013 9:41 pm
Well the orginl plan was to add to the frame. I'm having a hard time finding a cab or a donor truck at the moment around me that's not totally jacked up with rust and dents
I guess my initial thought was itd be a lot cheaper to just find a cab for it
cumminsgirl
Re: CC Conversion
Postby RCCUMMINS89 » Sat Feb 16, 2013 10:51 pm
I put a crew cab on a std. cab frame... the easiest thing is to just do a 3" body lift.
I had to run a 3" body lift for the RC to fit on the shortened std. cab frame as well.
Re: CC Conversion
Postby cumminsgirl » Tue Feb 19, 2013 5:00 pm
One question I did have is
Will the body lines match from a 70s model or should I find an 80s
My ext cab is a 93
cumminsgirl
Re: CC Conversion
Postby RCCUMMINS89 » Tue Feb 19, 2013 5:14 pm
Use an 80s.... to match the 80-90s bed
Re: CC Conversion
Postby RumbleFish » Tue Feb 19, 2013 6:23 pm
70s and 80s cabs, rear doors, and door panels are all the same. The front doors determine the body lines that match the bed and fenders.
Re: CC Conversion
Postby RCCUMMINS89 » Tue Feb 19, 2013 6:49 pm
Ya, but if you put on a 70s cab it won't match the 80s bed
edit - * but you could use a 70s cab, and just put on the 80s fenders, and 80s front doors.... the 80s and 70s rear doors are the same.
Re: CC Conversion
Postby dazedandconfused » Tue Feb 19, 2013 6:52 pm
RCCUMMINS89 wrote:Ya, but if you put on a 70s cab it won't match the 80s bed
Why wont it? Use the newer front doors and the body lines are the same. The rear doors are the same from 70's and 80's trucks.
Re: CC Conversion
Postby RCCUMMINS89 » Tue Feb 19, 2013 7:08 pm
Yep, I edited about 10 seconds after I posted that.... was having a non productive brain fart.
Re: CC Conversion
Postby cumminsgirl » Wed Feb 20, 2013 7:10 am
alright thanks, this is def. going to be a large scale learning process for me :oops:
still no luck on a truck or cab at this point.
cumminsgirl
