fender molding
fender molding
Postby 93oneton » Mon May 06, 2013 9:23 pm
I'm looking to replace the molding piece that goes between the dually fender and the box. Any one know if you can get it any where?
Thanks in advance!
Shit happens
93oneton
Re: fender molding
Postby Black93 » Tue May 07, 2013 6:19 am
He lists the mopar part #. You might get lucky and find a new set. I know someone has to have a good used set.
http://www.mopartruckparts.com/tech/t013.html
Black93
Re: fender molding
Postby RumbleFish » Tue May 07, 2013 9:20 am
I might have a set yet. I've also heard of guys using the vw beetle fender to body gasket stuff too, it looks similar.
Re: fender molding
Postby 93oneton » Tue May 07, 2013 10:51 am
RumbleFish wrote:I might have a set yet. I've also heard of guys using the vw beetle fender to body gasket stuff too, it looks similar.
If u have a set I'd probably be interested in them. I have 2 sets but there both messed up. I'll also check out the vw stuff. Thanks guys!
Shit happens
93oneton
Re: fender molding
Postby firstgenjunkie » Tue May 07, 2013 7:04 pm
I used the VW fender welting for the original beetle and just had to trim little bits of it to account for the different bolt patterns.
1992 Dodge D350 Dually. EV2 Pyro & Boost, BHAF, Denny T Stage 2 pin, 366 spring, 4 inch exhaust and mildly tweaked pump. 2nd gen split bench, full replacement bumper/grill, and mobile comm suite.
firstgenjunkie
