Tilt Column Bearings?
both inside and out
Postby Burritoboi5 » Tue Sep 03, 2013 9:45 am
Anyone know where I can get some new bearings for the upper tilt portion of a 93 w350 column? My wheel has a good inch of lateral play in all directions and it is driving me nuts.
Thanks,
-Steve
Burritoboi5
Re: Tilt Column Bearings?
Postby 1STGENFARMBOY » Fri Sep 06, 2013 8:50 pm
Postby 1STGENFARMBOY » Fri Sep 06, 2013 8:53 pm
pull it apart and see if the snap ring that holds pressure on the spring has jumped out
of the slot, had it happen to me once, it's a bugger to get back in.
Return to Body
