Part number for exterior mirror glass?
both inside and out
Postby Fred_M1010 » Fri Jan 10, 2014 3:09 am
My mirror glass fell off, so I'm in need of a new one.
I looked at Rockauto, but they list a sh*tload of different mirrors for my truck...!?
Does anyone know which of them is the correct one?
I need an electric one for the left side.
I measured it to be about 8.6" x 6", so I thought the correct part was DORMAN Part # 51102, since that seemed to be the closest match...
But then I googled it and found that was for older trucks.... :?:
Any ideas?
Edit: while I'm at it, I might as well ask about part numbers for front wheel studs as well.
They had even more choices there :evil:
Thanks in advance! :D
-91.5 W250
Fred_M1010
Re: Part number for exterior mirror glass?
Postby CumminsPower59 » Sun Jan 12, 2014 6:54 pm
As for wheel studs, the OE size is Dorman PN 610-210. A common upgrade is 610-283, it's 9/16" diameter versus 1/2" diameter, longer and stronger. Of course you'd have to get all 9/16" lug nuts, but it's a good upgrade, especially if you run aluminum wheels, I bought 32 used ones in very good condition off ebay for $20. Beats the $2-$3 a piece at the parts store ;) I may or may not have a spare mirror, if need be, you can have it. I will have to check...
Postby TheSilverBullet » Mon Jan 13, 2014 12:37 pm
I went to oreillys and got one for a 73-87 chevy and it's damn near identical
Brownie-1990 w250 straight six standard transmission 445k odometer quit in 02 lol
The Silver Bullet-1998 qcsb 12v twins and a 6 speed
Blue bear- 2001 3500 pee pumped 24
TheSilverBullet
Postby Fred_M1010 » Tue Jan 14, 2014 2:11 am
CumminsPower59 wrote:As for wheel studs, the OE size is Dorman PN 610-210. A common upgrade is 610-283, it's 9/16" diameter versus 1/2" diameter, longer and stronger. Of course you'd have to get all 9/16" lug nuts, but it's a good upgrade, especially if you run aluminum wheels, I bought 32 used ones in very good condition off ebay for $20. Beats the $2-$3 a piece at the parts store ;) I may or may not have a spare mirror, if need be, you can have it. I will have to check...
Thanks, that would be great!
-91.5 W250
Fred_M1010
Return to Body
