Aftermarket bumpers
Postby DTanklage » Wed Jan 21, 2009 9:49 am
'91 Cummins wrote:Is it in the newest Batman movie? I could've sworn I saw a 2nd Gen Dually Cummins in that movie...
yupp, thats the one. i bought it from the movie studios in burbank calif
then, when the batman movie came out, a buddy called me adn told me it was in it
checked for myself and sure enough - it was this truck
you can see in the bed where they removed a large transfer tank. everywheres else is rhino lined. they sprayed some gloss black where the tank used to be. pause the movie and you can see it and you will know - well, you would if you had seen the bed of this truck
DTanklage
Postby 92 red cummins » Wed Jun 10, 2009 4:22 pm
trail ready makes a good bumper
92 red 4x4 w250 dodge grille guard,KC lights,warn winch,hella fogs,advanced timing,k&n,
92 red cummins
Postby CE_TX » Wed Jun 10, 2009 6:31 pm
Reunel makes a nice bumper, little pricey but BEEFYYYY!!!
1985 Dodge W350 Crew Cab with 1992 Cummins drivetrain---undergoing frame off restoration.
CE_TX
Postby matchew » Wed Jul 01, 2009 7:01 pm
Mine... I build them at my shop Cactus Coast Customs in Az.
92 1 ton, 7" lift 37 military MT's on Hummer Alcoas, HE341, 4" downpipe to tailpipe, killer front bumper, 14mm H+R, +40 injectors, 03 dodge seats, loud tunes. 'Custom' Rustoleum paint.
matchew
Postby DTanklage » Wed Jul 01, 2009 10:07 pm
that is one nice lookin bumper
DTanklage
Postby matchew » Thu Jul 02, 2009 8:34 pm
I'll thank you much if you would be talking about mine! It still needs a coat of good paint or powdercoat but it works well with the truck for now. My wife has nightmares about Waterworld (Don't know why, it doesn't float) and Mad Max (I get that one alot!) but has come to like the idea of a big @$$ truck and a huge bumper to cap it off. Now to get on the quad cab swap and tube flat bed with a 18" bob on the back!
matchew
Postby PToombs » Fri Jul 03, 2009 5:57 am
Don't go with powder coat. All it takes is 1 little chip, and the rust starts. Then, it migrates all under the coating, which then comes off in a sheet. I had a plow with powder coat on it. It had a 1/2 inch bubble on it, so I scraped it off. The coating came off in a piece about 4-5 inches across, rust all under there. You couldn't even see it until you tried to clean it.
I'd go with paint, for easy touch up, or some bedliner stuff. That bedliner is awesome siht, it takes some abuse. ;)
Postby Richie O » Fri Jul 03, 2009 12:36 pm
That bumper looks like it is not people friendly. Jaywalkers beware. Reminds me of a guy that got hit in the road by a truck doing 60 with plow gear. MESSY. :shock:
Postby matchew » Fri Jul 03, 2009 5:05 pm
I only worry about the cars that cut me off... it could be used as a launch platform if I hit one!
matchew
Postby james-93-12valve » Thu Jul 30, 2009 10:09 pm
rbrettctd wrote:Here mine, made by www.southwestfabricators.com .
Nice Truck
93 d350 5spd 4inch exhaust to a 6inch tip pump tweaked
james-93-12valve
Re: Aftermarket bumpers
Postby pratty85 » Sat Mar 06, 2010 2:20 pm
Check out http://www.bumperdude.com/ he has one to fit the first gens that will run you about $850 front and $350 for the rear
92 Dodge W250 EX CAB, 4x4, Auto, 6" Skyjacker Lift, 4" exhaust, 35X14.50 Nitto Mud Grapplers, 16X12 MT rims
pratty85
Postby DieselSharker » Wed Mar 10, 2010 9:12 am
I have the old Warn. The PO took the winch off but when I can afford it I will get another. The top diamond plate was getting rusty and the chrome was pretty scratched so I wire-brushed it and put a few coats of Herculiner on it.
Before (with hood ornaments for your enjoyment):
After:
1991 W250 727, 6" Skyjacker, 37" Dick Cepeks, Gear Vendor O/D, SDX 5x.014s, BHAF, home-made 4" intake, VE tuning & DennyT II pin, GDS 60mm with 16 cm, CoolerTubz 3" crossover
SUPPORT YOUR VETERANS!
DieselSharker
Postby Tintacker » Wed Mar 10, 2010 7:18 pm
If your in the southeast, these guys are up the road from me and the stuff I have seen from them is quality. And prices look great.
http://www.kenmtnac.com/WiDodpre94.html
I hope to get a bumper from them this summer.
As for the hood ornaments, :mrgreen: God bless Texas.
SOLD: :( '92 W250 LE auto PDR 190's, 3200 spring, Skyjacker 2" front springs with Bilstein 5100s
'01 2500 QC/SB 4X4 6sp, camper puller
Tintacker
Postby KTA » Thu Mar 11, 2010 3:52 pm
I think the ornaments made it look better! :-)
Postby DieselSharker » Thu Mar 11, 2010 4:21 pm
KTA wrote:I think the ornaments made it look better! :-)
Ditto. Unfortunately I couldn't take them home and let them ride on my hood/bumper while I'm driving so I went with the Herculiner. 8)
DieselSharker
