Finally LMC has done it!
both inside and out
Re: Finally LMC has done it!
Postby PToombs » Mon Apr 21, 2014 5:46 pm
I looked thru the online catalog and thought there was a decent amount of parts in there. Hopefully Bob is wrong and we tightwads can loosen up enough for them to keep making parts.
Postby Diesel » Tue Apr 22, 2014 1:12 pm
Bob is right - we need to buy!
A small update: I received my first LMC order today. This was for a 60's 4x4 GMC truck I have. Particularly to note was the rear bumper I ordered. It was sent in primer. I have to be honest and say it is beautiful and the finish seems very very stout. Will it be perfect for 20 more years? I don't know but I hope they prepped the surface properly so it doesn't rust for 100 more years.
I also bought a body mount kit in rubber. They seem to be fine. Not the same quality as OE but I can't say they are bad in any way. Just a different composition. Again, hopefully they don't crush out in the next year - we'll see.
Finally the hardware I bought. This included body gaskets, and metal parts like battery hold down stuff. This stuff was as good or better than OEM.
So jury is out on the other stuff pending a long term test but the small bits look/feel great.
1991.5 D250 Intercooled A518
Diesel
Postby tim curran » Fri Apr 25, 2014 6:41 pm
Just got my catalog in. I like what I see. Gonna ad some bling to the smokey old girls :twisted:
1993 w250, 3200 RPM springs, maxed fuel screw, industrial inj. Fuel pin, Dynamite diesel 75 horse inj., ind inj stage 2 pump, 60 lbs valve springs, ARP head studs, Banks ram air intake. 4 inch diamond eye exhaust,16cm turbo housing, 60 mm comp. Housing, BD tourqe converter, billet flex plate, Banks gauges, 212hp 608 tourque, old smokey and worn out.
tim curran
Postby dazedandconfused » Fri Apr 25, 2014 6:50 pm
I got mine as well. It has some good things in it but needs more stuff.
Return to Body
