Radiator core suport question
Postby hotdog » Wed Feb 19, 2014 7:54 am
Will a 92 gasser core support work on a 93 diesel? they look the same but maybe the diesel has a few tabs for inter cooler thanks
hotdog
Re: Radiator core suport question
Postby tim curran » Mon Feb 24, 2014 7:12 pm
Nothing a welder and a torch won't fix
1993 w250, 3200 RPM springs, maxed fuel screw, industrial inj. Fuel pin, Dynamite diesel 75 horse inj., ind inj stage 2 pump, 60 lbs valve springs, ARP head studs, Banks ram air intake. 4 inch diamond eye exhaust,16cm turbo housing, 60 mm comp. Housing, BD tourqe converter, billet flex plate, Banks gauges, 212hp 608 tourque, old smokey and worn out.
tim curran
Postby Hansen01 » Mon Feb 24, 2014 7:18 pm
Pretty sure the radiator mounts are different, but could be remade
Under construction...
Hansen01
Postby cmann250 » Mon Feb 24, 2014 7:26 pm
Hansen01 wrote:Pretty sure the radiator mounts are different, but could be remade
Gas radiator 28" wide, diesel radiator 31" wide.
The radiator mounts are pinch welded on, so they'd be a lot of work to undo but not impossible.
