cab question
cab question
Postby ohioelcamino » Tue Mar 18, 2014 8:43 pm
hi guys
im new to dodge trucks, and I found a great deal on a 76 dodge 1 ton dumptruck it has a 360 with a 4spd trans and is 2 whl drive. the truck is in great shape except for the cab it is completely shot. my question is what years cab and front clip can I put on this frame with out modification.
thanks
ohioelcamino
Re: cab question
Postby simplysmn » Sat Mar 22, 2014 10:43 pm
Mid 70's to 1993 should all bolt up body line is same from 81 to 93
simplysmn
Re: cab question
Postby 1STGENFARMBOY » Sun Mar 23, 2014 5:49 am
Mark Nixon could tell you for sure if there was any differences, if I hadn't have been a smart ass and
ran him off this site he would still be here, i'm sorry........maybe someone on here can give you his contact info.
Re: cab question
Postby DodgeFreak » Mon Mar 24, 2014 5:14 am
You have to pay attention to the trans tunnels. the 2wd autos in the 70s didn't have a wide hump, the majority of 80s up cabs had a wide hump in them. you can run the 72-93 front clip as long as you run all from the same year, because headlights\rad support and grille are different between some years.
Re: cab question
Postby CumminsPower59 » Mon Mar 24, 2014 6:28 pm
Darn near ALL 2wd auto trucks had a small center tunnel. I used a 93 cab and it came off a D150 auto truck...small tunnel.
Auto 2wd = small tunnel
Auto 4wd = large tunnel
Manual 2wd = large tunnel
Manual 4wd = large tunnel
club cab = all large tunnel
crew cabs = all large tunnel
Not 100% sure, but 99% ;)
There may be a few odd balls out there but I wish Dodge had used just ONE tunnel in all of the cabs...would've made my cab swap a lot easier...
Re: cab question
Postby DodgeFreak » Mon Mar 24, 2014 7:51 pm
weird because I have at least 3 cabs that's mid 80s to 90s with the large tunnel all 2wd.
actually I know for a fact that my 85 crewcab had the large hump 2wd auto because we just cut the hole for the shifter.
I should rephrase my first statement. 2 cabs for sure are 90s and 1 I am un sure of.
Re: cab question
Postby CumminsPower59 » Mon Mar 24, 2014 8:12 pm
Like I said on the crew cabs/club cabs, all large tunnels.
Dodge built so many weird combinations over the years...hard to keep track of the oddballs.
Re: cab question
Postby DodgeFreak » Tue Mar 25, 2014 9:34 am
Ahh I missed that part. You can add 2wd auto cab and chassis large hump to the list also. I'll have to look at the other cab and see if it for sure has a large hump......maybe it doesn't..I've had so many trucks come and go I can't keep them all straight.
