Factory Paint Color Options
Postby matthewh » Mon May 05, 2014 8:47 pm
So while investigating my leaking cab issue, I've found alot of little issues, rust starting on pass door due to the mirror brackets, drivers rocker, dent in pass bed side, etc.
Figure by the time I'm done fixing everything, it'll need paint, so its a good time to make a change. Currently its white with silver stripe in the middle, but I saw Hager's truck, blue with silver bottom, that appeals to me, or black with silver bottom.
Either way, does anybody know what the blue color would have been for our trucks? I'll post a pic if u can figure out from this effin phone
Edit, see if this works
http://s305.photobucket.com/user/MHaver ... sort=3&o=0
matthewh
Re: Factory Paint Color Options
Postby simplysmn » Wed Aug 13, 2014 11:05 pm
the Blue is a Dark Blue Metallic I would have to look up the paint code but that is the color my crewcab is going .
simplysmn
Postby crossy » Thu Aug 28, 2014 1:20 pm
ONE of the dark blue metallic codes is B2 or PB2 as it will appear on the cowl tag- that's what my 90 is. it has the light blue metallic QB6 as the center color and I really like it.' very different from most w/o being gaudy. Crossy
1990 D250, 5spd, 3.54, 35K miles,' Lomi '
1991 D250, 5spd, 3.54LS, fix-r-up toy, all stock,resto,'Pbob'
1992 D250, 5spd, 3.54LS,'CandyCane', almost daily driver
1992 W250,CC,auto,3.54LS,Picker
1990 D250,auto, 3.07, 'Doubleblue'
1973 Pinto w/ 13"cragars- ewww!
Sold 9 other 1st Gens that WE saved from death :-) and 3 that I couldn't save:-( - not counting gassers
crossy
