Body mount bolt sleeve
Postby SledNeck91604 » Wed May 21, 2014 6:30 pm
Hey guys, Im doing a little restoration. Im using a '90 frame with an '89 cab and a few parts off of an '86. My issue is i don't have a reliable measurement for the bolt sleeves. The 90s are rotted, the 89s seem to be too short at 2.350/2.720" and the 86s are too long for sure at 2.875/3.187".Hopefully someone else has some measurements.
SledNeck91604
Re: Body mount bolt sleeve
Postby SledNeck91604 » Fri Jul 13, 2018 6:57 pm
Anyone have their truck apart?
SledNeck91604
Postby PToombs » Sat Jul 14, 2018 4:39 pm
I just had a fender off, what do you need?
Postby SledNeck91604 » Sat Jul 14, 2018 5:07 pm
I need the proper length for the metal sleeves in the body mounts.
SledNeck91604
Postby PToombs » Mon Jul 16, 2018 4:11 pm
Sorry Chief, can't help you with that. Do you have the mounts out? Stack them up and measure the height, that should be close.
I just went and looked in my parts book, it doesn't show the sleeve, just the rubbers.
Postby SledNeck91604 » Mon Jul 16, 2018 4:24 pm
Thanks for looking!
SledNeck91604
