we're back baby! :D
we're back baby! :D
Postby captmatthew1 » Wed Jul 23, 2014 5:07 pm
sooo....some of you may remember where the old truck stands (or stood before it went into storage)
Well, since i will be making the trip to wisconsin to remove it from its storage unit, I will actually have a reason to post again! I leave the 26th to go get it, until then i sit here impatiently waiting...
1992 W250 5 speed, pump maxxed, 366 spring, caravan seats, white gauges, more to come.
captmatthew1
Re: we're back baby! :D
Postby dazedandconfused » Wed Jul 23, 2014 5:38 pm
Whatever came of that whole deal?
Postby matthewh » Wed Jul 23, 2014 6:26 pm
Wow, what happened?
matthewh
Postby captmatthew1 » Wed Jul 23, 2014 8:23 pm
i got an insurance payout. it wasnt nearly enough to pay for the damage but i took it to keep the lawyers out of it. and btw, this is what happens when well trained walmart associates try to change the oil on a truck...thats what being lazy gets me.
captmatthew1
Postby captmatthew1 » Wed Jul 23, 2014 8:24 pm
the person that was changing my oil started my truck while it was still in reverse and it took off on him. kinda funny when its not your vehicle (and i have even laughed a couple times.)
captmatthew1
Postby captmatthew1 » Wed Jul 23, 2014 8:32 pm
here is some pictures of it post accident. and a couple of what i was up to around the time it happened. might as well be a pic whore while i wait to see it again in person...
and what i was up to before everything went wrong.
captmatthew1
Postby oldestof11 » Thu Jul 24, 2014 4:03 am
Dude. I would have gotten a lawyer involved. Walmart would have paid handsomely.
What are your plans now?
Postby captmatthew1 » Thu Jul 24, 2014 4:12 am
the problem with getting into a lawsuit with a large company such as walmart, is they have unlimited resources for things like lawyers. they would have worked their way around it somewhere.
at any rate, when it gets back i will be leveling the front suspension on it to clear some larger tires. get the body work done and painted. i will be using it in the mountains as my wood hauler/hunting truck. wont abuse it though. its got to stay in good shape once i fix it. luckily i moved back to the west coast so i wont have the trouble of finding the body parts for it :D
captmatthew1
Postby Tacoclaw » Thu Jul 24, 2014 11:02 am
Not much to sue over if he disabled his clutch switch, allowing it to be started in gear. (What I assume happened.)
Even worse if Walmart decided to twist the knife and charge him for a door and other damages because of it.
Postby captmatthew1 » Thu Jul 24, 2014 11:11 am
you hit the nail on the head. thats why i didnt press the matter any further than i did. i got some money out of the deal so it worked out ok in the end :)
captmatthew1
Postby Tacoclaw » Thu Jul 24, 2014 2:23 pm
I've got everything disabled on my truck, I don't let anyone near it without a long talk about how it'll kill them if they stop paying attention for even one second. :lol:
Postby captmatthew1 » Fri Jul 25, 2014 6:37 am
:lol: yeah, his excuse was that he didnt know it was a manual...nevermind that he drove it in there and there is a HUGE stick protruding out of the floor with numbers on it...
captmatthew1
Postby captmatthew1 » Thu May 21, 2015 6:55 pm
new bed! finally starting to collect parts. picked this baby up for $225.
tailgate panel is almost perfect. couldnt be happier with it. have a couple holes to weld up, but no rust and mostly straight.
captmatthew1
Postby DodgeFreak » Thu May 21, 2015 7:19 pm
I need the tail gate lol....
Postby captmatthew1 » Tue Feb 02, 2016 4:00 am
so...its been a while, but i finally started on the body/mechanicals. here are some progress pics.
i started with repairing the threads on my shifter locating pins. this has worked perfect, so if anyone has issues with stripped out holes, this may be a good solution.'
drilling out the holes, i epoxied some t-nuts into the holes. it was cold outside, so using a heat gun, i kept the epoxy warm to aid in the curing process.
once the epoxy had hardened, i modified a couple button head allen screws to replicate the original pins.
then the dust boot went on with an exhaust clamp from an old turbo to hold the whole assembly together for strength.
then the whole assembly went back together.
captmatthew1
