Door Vent Window Seals
Postby Horicon93 » Thu Aug 21, 2014 6:03 pm
The vent window seals on both my doors are leaking water, at the bottom, right where the pivot stud is. Are these seals available anywhere?
'93 Extended Cab, DRW, 2WD, Auto, 4 1/2" stacks, Bone Stock
Horicon93
Re: Door Vent Window Seals
Postby ellis93 » Thu Aug 21, 2014 6:18 pm
JC Whitney and LMC
Postby Horicon93 » Thu Aug 21, 2014 6:51 pm
LMC only lists a vent window seal kit for 78-86 models.
Whitney has nothing.
Rock Auto has nothing.
MoparPart.com has nothing.
Horicon93
Postby ellis93 » Thu Aug 21, 2014 7:12 pm
I looked and your right,Whitney has every thing but what you want. The do have the 78 to 86 stuff tho.....whatever that's worth,nothing. Crap.
Silicone?
Postby Horicon93 » Fri Aug 22, 2014 3:55 am
I imagine silicone would in fact work, but I do use the windows, so this wouldn't be a viable option. The water comes down the window and then seeps between the gasket and the window at the pivot point on the bottom. I'm thinking I may just have to put out a WANTED ad for some good wing window assemblies in the classifieds.
Horicon93
