Rocker Panel Replacement?
Postby 93DodgeCummins » Wed Oct 01, 2014 7:28 pm
I have the ext cab and was wondering if there are any rocker panels out there that have the curved corner? I know I ill probably end up modified two of them to get the length for the ext cab but just cant find one with the corner piece.
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Re: Rocker Panel Replacement?
Postby thrashingcows » Fri Oct 03, 2014 9:00 pm
I believe they are two different pieces. Rocker panels, and cab corners.
thrashingcows
Postby kethryes » Mon Oct 20, 2014 5:34 pm
I don know if this would help you but lmc truck now has parts for the trucks
http://www.lmctruck.com/icatalog/dc/full.aspx?Page=13
kethryes
