Anyone have this?
Anyone have this?
Postby Firstgen11 » Mon Dec 29, 2014 1:26 pm
Anyone have a picture difference of a non intercooled and an intercolled core support for our 90-93 trucks?
Firstgen11
Re: Anyone have this?
Postby simplysmn » Mon Dec 29, 2014 11:56 pm
there is a big difference in headlight possition and the way the Rad sit's on the IC truck's it sit's deeper into truck so IC can fit on the out side of Rad.
simplysmn
Postby Firstgen11 » Tue Dec 30, 2014 11:32 am
Yeah I need a picture so I know to order the right one
Firstgen11
Postby CumminsPower59 » Tue Dec 30, 2014 2:34 pm
I am curious as to why you would need to have a picture of one? The IC ones are pretty easy to spot, as there is two oval shaped holes, one on each side of the radiator opening towards the bottom, for the intercooler. The only oddball ones are on the early 91's, as they have the correct positioning for the headlights to use the IC style grille, but use the NON-IC mounting of the radiator and have no intercooler openings on the sides of the radiators.
