Tips, Tricks, Reinforcements for Cab Off Resto
Postby ropinfool » Sun Jan 11, 2015 4:31 pm
What types of things are good to do while the cab is stripped and off the truck for a resto? I have found some info about reinforcing the cowl area with a metal patch to prevent or repair cracking; adding a drain to the clean air vents to remove water and debris that build up; adding reinforcements to the door skin and lower hinges; and cutting an access panel into the roof, using a donor roof to make a larger panel so as to get access to the inner portion of the outer roof skin. I have links on my PC that I can upload later if anyone needs clarification. Aside from the previous, are there any other bodymods that would be good to tackle while I can rotate, maneuver, and weld on the bare sheet metal?
1990 D250- 5 speed, reg cab, long box, boost & pyro gauge, aluminum flat deck.
ropinfool
Re: Tips, Tricks, Reinforcements for Cab Off Resto
Postby Ghostman » Tue Feb 03, 2015 9:17 am
post up the links you have.
Restoring a Early '91
2001 12v
(2) 2002 24v
Ghostman
Postby ropinfool » Sat Feb 14, 2015 12:19 am
I will bring my computer to town the next time I run down the mountain and post them up.
ropinfool
Postby ropinfool » Wed Feb 25, 2015 4:27 pm
Here is some of the info I found, (we cleaned our PC and my bookmarks got erased.) None of these are mine, just resources I am referencing.
Door handle reinforcement: http://ramchargercentral.com/mopar-truc ... rig!!/850/ (starts mid way down the page.)
Inner door skin reinforcements: http://ramchargercentral.com/mopar-truc ... rig!!/700/ (starts mid way down the page.)
Cowl cracks/ repair: http://wiki.dieseltruckresource.com/wiki/Cowl_Fix
http://www.dieseltruckresource.com/foru ... ks-238712/
Lower door hinge reinforcement/ innner roof acess panel : http://www.dieseltruckresource.com/foru ... 23/page37/
(lowe hinge theory only, no real finished product) http://www.dieseltruckresource.com/foru ... last-post/
Seems like most of the repairs or reinforcements are around the doors on these old trucks. There is more info out there, this was what I could easily find.
ropinfool
