Rubber body mount bushings
Postby 69HemiGTX » Sun Jan 18, 2015 10:43 pm
OK, I need to know if there are any sources for rubber body mount bushings - NOT POLY. I don't want any poly bushings anywhere. I know they have to be available somewhere.
OIF and OEF veteran
98.5 24V CTD 4x4, AEM Brute Force intake, silencer ring MIA, Diamond Eye 4" stainless exhaust, more to come...
78 RC 4X4, 360, auto, original condition survivor, stuck in the back of a garage
78/84/93 Crew Cab Dually, Cummins, NV4500, 4x4 conversion, ugly as sin
69HemiGTX
Re: Rubber body mount bushings
Postby PToombs » Mon Jan 19, 2015 6:48 pm
Pretty sure dealer only. I looked around after I put in poly mounts and couldn't find any. If you do find some let me know, I'm not real happy with the poly ones either.
Postby rollieD250 » Wed Nov 25, 2015 1:02 pm
Bump!! Anyone have a lead? My passanger side is sagging down and i really want to fix it but cant find bushings, thanks!
1992 D250
THD fuel pin, 3200 spring, 57/65/14, timing spacer, 3pc manifold, piston lift pump, ASA intake
rollieD250
Postby thrashingcows » Wed Nov 25, 2015 2:12 pm
The NOS ones are almost all gone. I have some poly ones under my crewcab, and would love to get them out of there too. I looked for them through the dealer and was only able to find the lower ones, and I think one other upper mount. The rest are no longer available.
For a time I was looking for an aftermarket solution, found some mid/late 60's GM car body bushings that looked promising, but never finished my research.
thrashingcows
Postby rollieD250 » Wed Nov 25, 2015 2:19 pm
Are the poly bushings really THAT bad??
1992 D250
rollieD250
Postby PToombs » Wed Nov 25, 2015 6:26 pm
Several of the stock mounts are NLA, no longer available from Dodge, not even any dealer stock left.
The poly ones are quite a bit stiffer, and transmit a lot more vibration to the cab. I've gotten more used to them now. I have a vibration in the truck I can't find that comes on about 65mph, and I feel it pretty good. The rest of the time I don't notice the vibration as much as I did last summer.
Postby rollieD250 » Wed Nov 25, 2015 9:22 pm
I went ahead and ordered the energy suspension poly mounts....i will be incredibly happy if they work and pick my cab back up in line with my bed :D
1992 D250
rollieD250
