Best vent window seals
Postby Jelmer » Fri Feb 13, 2015 5:39 am
What is the best brand to buy regarding vent window seals?
Greetings from the Netherlands where there are only 2 or 3 1stgens!
93 D250 Cummins, G360, 4" stainless exhaust, BHAF, DennyT stage 2 pin, 3200rpm governor spring, 12cm housing, rest stock.
03 VW Bora 1.6
83 Datsun Laurel 4.5 32v V8
84 Nissan Patrol 2.8i
Jelmer
Re: Best vent window seals
Postby jerseybud » Sat Feb 14, 2015 6:57 pm
There is no such thing. The aftermarket does not make seals for the 87-93 trucks and the last time I saw a NOS single or pair was 4 years ago. keep what you got or find a good used pair.
1993 W250 a518 3.54LS. Has a hx35. Needs a beefed tranny
jerseybud
Postby oldestof11 » Sat Feb 14, 2015 7:24 pm
Unless 87-93 is different, here is 79-86 set
http://m.1aauto.com/vent-glass-window-w ... aQodyDgAVw
Postby thrashingcows » Sat Feb 14, 2015 10:05 pm
Those reproductions one will work with just a little modifying if I remember correctly. I believe there is a write up over on the DTR on how to use those seals on our newer trucks.
thrashingcows
Postby Jelmer » Mon Feb 16, 2015 5:18 am
Thanks. Our current ones are not sealing anymore because they are to hard/stiff.
03 VW Bora 1.6
Jelmer
