Power window regulator questions??
Postby rollieD250 » Thu Aug 27, 2015 6:07 pm
Rebuilding my 92 d250 and i want to get new regulator/motors for the windows....LMC and everyone else only list the regulators up to 1990. Does anyone know if these will work in a 92-93? Find it hard to believe they changed them but id like to know if anyone has info....
THANK YOU !!
1992 D250
THD fuel pin, 3200 spring, 57/65/14, timing spacer, 3pc manifold, piston lift pump, ASA intake
rollieD250
Re: Power window regulator questions??
Postby simplysmn » Thu Aug 27, 2015 9:19 pm
I believe what they changed is the Gear on the window Motor . the Later truck's have a bigger gear so you have to open the hole for the motor gear up to meet that size . Geno's Garage sell's the motor's also new .I would have to check to see if they have the regulator's also .
simplysmn
Postby thrashingcows » Fri Aug 28, 2015 1:43 am
Here's one for a 91.5-93...off E-bay...should be a direct swap.
http://www.ebay.com/itm/Power-Window-Mo ... 8c&vxp=mtr
thrashingcows
Postby rollieD250 » Fri Aug 28, 2015 3:55 am
Finding the motor is no problem, its the regulator i cAnt find....maybe i can buy the regulator/motors for a 90 and install them !
1992 D250
rollieD250
Postby thrashingcows » Fri Aug 28, 2015 11:23 am
Ahhh I see...misunderstood. Pretty sure they make the regulators as well. Will do some digging.
But pretty sure you can use a pre-91 PW assembly in the later doors. You might just have to drill a couple new holes. I believe, but am not 100% sure, that the pre 91 units bolted in, as opposed to the 91-93 units being riveted in.
thrashingcows
