Poly Cab bushings?
Poly Cab bushings?
Postby Collers9640 » Fri Oct 13, 2017 11:15 pm
Does anyone have any advice before I change my cab bushing. Like how to percent them from squeaking!!
Has anyone found a company that makes rubber body mount bushings?
Collers9640
Re: Poly Cab bushings?
Postby Philip » Sat Oct 14, 2017 6:34 am
http://www.jegs.com/i/Energy-Suspension ... gIsuvD_BwE
About the only thing to try. Like grease it will go away after a while.
Postby PToombs » Mon Oct 16, 2017 4:18 pm
If you are fussy about the ride don't put in the urethane bushings! They are stiff and transmit a lot of vibrations right to the cab. I put in a set because my mounts were squashed down and shot, and have regretted it ever since. If yours are still good, try that stuff Philip listed. The mounts that actually support the body are no longer available, but some of the bottom ones are. I looked last summer because I was going to change mine back.
Postby Collers9640 » Thu Oct 19, 2017 9:18 am
I know that polyurethane comes is different levels of hardness.
I wonder what hardness companies like Prothane are using.
I’m going to do some research to see if a softer polyurethane can be used without compromising the structural integrity of the bushing.
I’m confident that we might be able to make our own bushing provided that a good poly can be found.
Collers9640
Postby thrashingcows » Thu Oct 19, 2017 1:45 pm
Stay away from grease on the poly/urethane bushings....I did this on my cab mounts, and even after tightening them down excessively the cab was still shifting on the mounts due to the grease. Eventually had to remove the mushing one at a time, clean everything up and re-install dry....cab has been secure ever since.
thrashingcows
Postby PToombs » Thu Oct 19, 2017 4:17 pm
I got the Energy suspension set. I know they are stiff, I didn't know about the different polys.
Postby bensol64 » Wed Nov 14, 2018 1:18 am
I have the Energy bushings on my rig also and have no complaints so far.
'92 W350 5speed 4x4 with 17" wheels and 33" ironman tires
bensol64
Postby 2uphill » Sat Jan 26, 2019 8:03 am
I wonder if a layer or two of a pc of inner tube cut to size/shape would help? (Top and bottom)
90 d350, SRW, 2wd, 727, stock, except banks i/c, 85K
84 w350 crew cab, I/c 89, s300, 727, 4x4, 130K
90 w350cc, 3.54, getrag, 125K
82 d350 crew cab project
2uphill
Postby BC847 » Sat Jan 26, 2019 10:07 am
Postby PToombs » Sat Jan 26, 2019 6:35 pm
They don't hold up to petrol and lubricating oils, better fi the leaks! :lol: How much is 47 pounds in American dollars?
Postby 2uphill » Sun Jan 27, 2019 7:38 pm
Truck tire tubes.. thicker... or even a pc of thin plastic cut off of plastic jug??? Top and bottom
2uphill
