Dash Bezel
Dash Bezel
Postby ekk33 » Tue Mar 11, 2008 6:28 am
Does anyone know if the LE woodgrain dash is the same as the black one without the woodgrain, i prefer the black one. I was wondering if it is possible to strip the woodgrain off and clean up the glue? Then paint it black,
Thanks for the help,
Eric
1992 W250
Cooler Tubz, PS Intercooler
Pump Mods,3200 Spring,
ekk33
Postby GO OVRIT » Wed Mar 12, 2008 8:42 pm
They go cheap enough in bone yards and ebay, that I wouldn't spend that much time. You can use a gas one too. I had a black one laying around for awhile, and just decided to use it a mud bogg truck that my brother and I are putting together.
GO OVRIT
Postby Bogie » Tue Apr 08, 2008 1:23 am
Yes you can remove the woodgrain I even took off the silver around the openings its all black now
1984 Dodge W350 Crew Cab 9"Lift 37" SSR's 360/NP435 D60's W4.10's
1966 Dart 273HP 4Speed 3.90's Radio/Heat Delete
Bogie
