wheels
wheels
Postby 89silverbullet » Wed May 07, 2008 6:48 pm
what years of dodge match up to first gen nut configuration. Do the powerstrokes lugs match the first gen? what is a good company for good looking after market wheels? just want the rig to look good 8)
1989 d250 muffler delete diaphram turned, fuel screw turned, the lowes special intake
89silverbullet
Postby GO OVRIT » Wed May 07, 2008 8:22 pm
Any Dodge and Chevy 8 lug is the same, and 98 and older Fords. Superduties and Excursions use a metric 8 lug pattern.
GO OVRIT
Postby BEARKILLER » Wed May 07, 2008 9:53 pm
Until Ford introduced the "Super Duty", all 8-lug wheels shared a standard 8-on-6-1/2" bolt-pattern, both SRW and DRW.
BUT, Chevy/GMC, although the pattern is the same, have a much too small center opening that WILL NOT clear the Dana hubs found on nearly all Fords and Dodges.
A machinist's lathe can be used to enlarge the too-small opening of the Chevy wheels to clear the Dodge hub.
Also, the factory steel wheels that came standard on the Fords are of much superior construction than the Dodge wheels.
#4 = 1991 D-350 LE Getrag
BEARKILLER
I Like Rickson
Postby Ace » Thu May 08, 2008 6:47 am
For my money, Ricksons with the commercial grade 19.5 tires are the best wheel/tire combo available.
Unfortunately, a big chunk of what I thought was disposable income went to the IRS again this year, so I won't be getting them anytime soon. :roll:
Ace
Postby KRB64 » Sun Jun 15, 2008 3:48 am
Where's a good place to get non-chromed lug nuts? I need some enclosed ones that protect the threads but can't stand chrome.
'92 W250 CC LE, auto, OD on shift, 3.54 limited; boost/PT pyro/tranny, oil temp, fuel press, tach; Bosch 190s, Ol' Smoky, 366 spring, full fuel, pull cable, 1/8" bump, synthetics, Borgeson, aFe, 16cm house, 4" pipe, AT cooler, ton shoes, ext reg...
KRB64
Postby Richie O » Sun Jun 15, 2008 8:01 am
KRB64 wrote:Where's a good place to get non-chromed lug nuts? I need some enclosed ones that protect the threads but can't stand chrome.
Go to a "true" parts store and ask to see there stud and lug book. Just match size and thread and you should find something. They should have illustrated books.
Postby RumbleFish » Sun Jun 15, 2008 5:02 pm
ill look through the dorman book next time i am at work, im sure thre is something in there. ill let you know what i find.
Postby PToombs » Sun Jun 15, 2008 5:06 pm
Hey, you're back at work? Good deal! 8)
See? Hanging with those Neon freaks you're forgetting to talk to the people who care, your 1st gen buddies! :shock:
Postby RumbleFish » Sun Jun 15, 2008 7:13 pm
not really, this is the part time parts store gig ive had for a while. im still laid off from the boat factory. and they are laying more off. fleetwood just laid off 300 this past friday. my town of 9500-ish is hurting pretty bad. i do have an inside contact on a job at the local soy bean refinery. rumor has it that it pays $19+/hr. i gots my fingers crossed.
and ill show you neon freaks....wanna line up my car vs your green goober? :finger:
Postby RumbleFish » Mon Jun 16, 2008 5:43 am
ok, i just cruised through the dorman book and your only options are stainless or black. i guessed you wanted non-shiny, so here is the info on the black ones:
p/n 611-123, made by dorman
1/2"-20 x 1 1/4" long, 13/16" hex, 60 deg. tapered seat. i work for o'reillys, so if you got one local you can get it there. otherwise, over the internet or another parts place that handles dorman should be able to get them.
Postby PToombs » Mon Jun 16, 2008 5:27 pm
RumbleFish wrote:and ill show you neon freaks....wanna line up my car vs your green goober? :finger:
Bring it on, biatch! :rambo:
Postby Richie O » Mon Jun 16, 2008 6:32 pm
Pete, If you leave your cab off you might just beat that neon. :cyclopsani:
Postby GO OVRIT » Mon Jun 16, 2008 7:04 pm
I've got bunches of them that aren't shiny enough anymore for my taste that anybody can have. :D They don't fit into my "Ban black wheels" campaign.
GO OVRIT
Postby RumbleFish » Mon Jun 16, 2008 7:08 pm
So, if i dont have a truck to take to sop, Ill take my neon so I can "bring it on biatch". I hope the ol' green machine can trap 111mph in the 1/4, cuz thats what it will take to get around me. Hey, I bet if we race while pulling loaded trailers you could beat me :jumpsmile:
Postby KRB64 » Tue Jun 17, 2008 1:02 am
Children, ya'll behave!
Thanks for the part numbers and details Rumblefish.
Go Overit - you really want to get rid of those "de-chromed" ones? If so, I'm interested.
When is SOP? I had a good time year before last and was sorry I missed last year (although northern California was fun).
KRB64
