3 Gen seats will they fit our trucks
Postby roxxx » Fri Jun 20, 2008 4:19 pm
i have a buckets in the shorty and a the bench in the quad seems to be way bigger than the shorty. I found a wrecked out 2005 1500 4x4 reg cab with a bench seat will it fit ?
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
Postby dpuckett » Sun Jun 22, 2008 4:22 pm
You will have to modify/ customize your brackets and such, but it is doable. After riding in the 04 Dakota, my 1stGen buckets are still more comfortable for me, but that's only an opinion. And opinions are like armpits......
Check the DTR for a 3rd Gen retrofit of the split bench.
I had a 94 split bench in my 91- worked just fine the time I had it.
Daniel
Postby Rug_Trucker » Mon Jun 30, 2008 10:37 pm
I had a 2001 split bench with the flip down cup holder whatever you want to call it given to me. I was thinking about recovering it and swapping.
The harnesses are integral with the seat.
72 slant Duster M-1 2bbl Hookers
79 Maxivan Offy Comp RV cam0
74 Dart 225 4 DR
93 D350 CTD auto
various KW's and Freighliners with 10spd auto shifts
Rug_Trucker
Re: 3 Gen seats will they fit our trucks
Postby pratty85 » Fri Feb 26, 2010 8:53 am
I have a bench seat with fold down console out of a 95, in my 92 ex cab. I had to make custom bushings to mount it properly.
92 Dodge W250 EX CAB, 4x4, Auto, 6" Skyjacker Lift, 4" exhaust, 35X14.50 Nitto Mud Grapplers, 16X12 MT rims
pratty85
