door wont shut right...
Postby railhor5.9 » Fri Aug 01, 2008 6:18 pm
my driver side door wont shut right i have to pick up on it and it still wont seal right,,, when i drive in the rain i get soaked , wat wears out or breaks in the hinge??? :evil:
1993 d250,single cab short bed, sbc, 175hp p-pumped,4kgsk,370's, fass 150. hx35
1997 2500 4x4 , 913,191's,3kgsk,5x16, 3rd gen dubs.
railhor5.9
Postby cummins king » Fri Aug 01, 2008 7:17 pm
your not slaming it hard enough, these trucks like to play rough and get slammed hard. :lol:
Didnt know i had it in me. :lol:
93 4X4 auto
cummins king
Postby mprmn08 » Fri Aug 01, 2008 7:25 pm
If you have to pick it up and slam it its most likely hinge pins. its a common problem with a older vehicle.
mprmn08
Postby railhor5.9 » Fri Aug 01, 2008 8:21 pm
i think thats it but i get soaked drivin in the rain
railhor5.9
Postby Philip » Fri Aug 01, 2008 8:52 pm
You need to replace the hinge pins. NAPA has them on stock. After the pins are replaced then readjust the door if needed.
Postby BEARKILLER » Fri Aug 01, 2008 9:02 pm
A friends doors got so bad that the driver-door was impossible to shut if it got opened and the passenger-side dropped a couple inches when opened.
A local body man installed new hinge-pins and adjusted the doors with a block of wood on a floor-jack; then, he installed new seals all around.
His doors now shut as easily as an early-eighties Ford; just push them until they "click", and no more rain funneling in.
I recently did the hinge-pins on two Dodges and my Ford; the difference is amazing.
#4 = 1991 D-350 LE Getrag
BEARKILLER
Postby redneckroot » Fri Aug 01, 2008 9:21 pm
I put new pins on my doors before i took the truck apart. Before you spend the whoping 10 bucks on them make sure that the hinges themselves haven't been warn into by the pin. Mine were so the pins and new bushings only let the door fall about 1/2inch so it didn't really solve the problem
redneckroot
An Ounce of Prevention
Postby Ace » Sat Aug 02, 2008 5:45 am
An ounce of prevention is worth a pound of cure. Put a drop of oil on the pins once or twice a year and they'll last forever.
Ace
Postby PToombs » Sat Aug 02, 2008 1:45 pm
Before you get real excited and buy pins and bushings, have a buddy lift the door and make sure the door isn't cracked where the lower hinge is bolted. ;)
Postby Richie O » Sat Aug 02, 2008 7:16 pm
I found that opening the door and backing up past a tree works great. It turns them into jeep doors that open all the way to the fender. :lol:
Postby PToombs » Sun Aug 03, 2008 10:50 am
Man, you do everything the hard way, dontcha? :shock:
