should i pull the motor?
Postby railhor5.9 » Wed Aug 27, 2008 9:58 am
last ctd blew up melted everything should i pull the motor and clean up the firewall?
1993 d250,single cab short bed, sbc, 175hp p-pumped,4kgsk,370's, fass 150. hx35
1997 2500 4x4 , 913,191's,3kgsk,5x16, 3rd gen dubs.
railhor5.9
Postby 1991cummins » Wed Aug 27, 2008 6:51 pm
i think you should, is it down to the bear metal... maybe just take off the hood (if you dont already) and see if you can get down in there and sand it and paint it..
what the hell happened???
1991cummins
Postby grumpy » Wed Aug 27, 2008 9:48 pm
looks like an electrical fire to me.pull it clean it up and stick it back in painted..
93 dodge w350 excab daully auto 3600 gov spring 4" streight pipe,hx-35/40 turbo
91 jeep xj trail rig I-6 5spd exo cage 7inch lift
87 35ft gooseneck trailer soon to have 79camper on it.
grumpy
