club cab
club cab
Postby T.winegar » Sat Sep 20, 2008 3:29 pm
i want a club cab for my friends to be able to ride with me instead of on top of each other in the single cab.
my truck is a 250 89 cummins with a single cab.
what would i have to do to either build a club cab and put it on the back, or swap the cabs with another truck??
possible???
89 727-stageIvcomp 4in intake-amsoil air filter, 4in exhaust, dennyT, 366 spring. pump turned up to make me smile! low stall converter, rebuilt tranny at 120,000miles
T.winegar
Postby burnt_servo » Sat Sep 20, 2008 3:58 pm
i've been tossing that idea round too ..........
have you thought about what your going to use for a box ?
'93 w250 .... stock ...
burnt_servo
Postby shadrach » Sat Sep 20, 2008 9:26 pm
Take a look at the shape of your frame and then look at one on a club cab. They are different, so it isn't a simple matter to just change cabs and use a short box. Shadrach
1) 1984 D350 Crew Cab 360 V8 auto [b]FOR SALE[/b]
2) 1992 Club Cab D250 auto- with 93 engine
3) 2003 Quad Cab Laramie 4X4 CTD HO G56 6 speed
shadrach
Postby 1991cummins » Sat Sep 20, 2008 9:38 pm
i would modify a sleeper or something... cause thats a big deal, you'd be better off buying a different truck.
coming from the guy that wants to do a 4wd conversion :oops: lol
1991cummins
Postby dpuckett » Mon Dec 01, 2008 9:28 pm
If you can stand to lose some bed space, get a McKinley conversion. Basically, they make your standard cab into a crew cab, but keep the bed in place. It looks like a cowboy sleeper from the outside, but it goes into the front of the bed. I'll see if I can find a link. There was a write up in the TDR about it a few years back. Only drawback is, they cost about $3000.
I got a club cab swb you can buy for parts ;)
Daniel
Postby KTA » Mon Dec 01, 2008 10:22 pm
Have you ever been in the back of a club cab 1gen??? I wouldn't make any of my friends ride back there, and I sure as hell won't be. I am only 6'1" and I feel smashed back there. The only thing that space is good for is hauling more tools and goodies or pets and little kids. Be kind and get a crew cab, the swap is just as easy anyways. 8) .
Postby sdstriper » Wed Dec 03, 2008 8:55 pm
A sleeper topper is the way to go, if you don't mind losing bed space. I got one with a door in the back between the seats. Now all the fricken thieves have to do is break the door glass to get my tools etc...
sdstriper
