PToombs wrote:Snoot, what's the weight rating on those rims? There was a little discussion on TDR or someplace about those rims, and it was all crickets after I asked that question.
Ace wrote:The only problem with wheel adapters depends on how thick you go and the width/offset combination of the wheels for steering purposes. If you get the wheel centerline pushed out far enough it will increase front tire scrub in turns to the point of negatively affecting steering response.
The other thing I'd worry about is bearing load on a 2wd front. The 4x4 Dana 60s are not even going to notice the difference in the range of 1"-2", but I woudn't go much thicker than that.
I've had 1.25" adapters on mine since spring this year. They put the outside sidewalls right out flush with the fender flares and allow 34" tires to clear lock-to-lock up front at full compression with only 3" of lift. Like you said and what I found the same, it's about the only way to go for anything really nice in a tire/wheel upgrade for the 1st gens, just be aware of the implications.
