wrecked
wrecked
Postby hassy21 » Mon Nov 24, 2008 4:15 am
i just rolled my truck over in ditch in the fog in central california and plan on replacing the whole body and changing my interior into the new cab. I was wondering if the gas '90 cab would fit my tranny and everything. any info on body swapping would be much appreciated. i know its a lot of work but i gotta fix that truck.
hassy21
Postby RumbleFish » Mon Nov 24, 2008 7:15 am
it depends on what the cab is from. if it is from a 2wd automatic, then the trans tunnel will be smaller. if it is from a 2wd manual, or a 4wd truck, then it will fit.
if your truck is a stick, it wouldnt be a bad idea to make a removeable trans hump in the floor anyway.
Postby hassy21 » Mon Nov 24, 2008 2:37 pm
i have an automatic but the truck i got for parts is a 2wd auto. how hard would it be to replace the hump on the trucks?
hassy21
Postby Richie O » Mon Nov 24, 2008 3:53 pm
Just cut out the hump and replace it with your hump. The rest of the floor boards and mounts should be the same. Sorry for your crunch, that sucks.
Postby hassy21 » Tue Nov 25, 2008 2:32 am
ya it sucks but i hadnt put a scratch on her 4 wheeling and other stuff so im not to mad at myself. i have pics i can post later on.
hassy21
