Door Issues Whats New
Postby Diesel Dan » Fri Dec 26, 2008 12:02 am
Well i knew that i needed to do some standard dodge door work on the truck and finally looked at it today and it looks as if the door was over extended or over opened resulting in taring the metal on the inside of the door next to the hinge. i was wondering if anyone else had this problem and if it is fixable or need to replace the whole door. the door is in great shape so i would hate to replace it if i don't have to.
i think i explained it kinda and i will post pics of it tomorrow
Dan :roll:
1992 cummins, 350, single cab, 8 foor bed (kinda), manual, 4x4
Right now Very ugly but its a cummins!
Diesel Dan
Postby PToombs » Fri Dec 26, 2008 6:54 am
Common thing. Mine was actually cracked inside. When the hinge went over the holding hump, it would make a snap noise. I had to weld up the end, and add a plate inside the door to beef it up.
Postby Diesel Dan » Sun Dec 28, 2008 10:17 pm
Here are some pics i promised and was wonderinf if you could explain the easiest way to fix this..
with a thin plate over the crack the size of the hinge footprint
or
just weld the crack
Diesel Dan
Diesel Dan
Postby dpuckett » Sun Dec 28, 2008 10:32 pm
Looks like a typical Dodge door to me. I'd have to think about how I'd fix it, short of replacing the doors. Involves a MIG and sheetmetal.
Postby Diesel Dan » Sun Dec 28, 2008 10:45 pm
or if there is a cheep door out there somewhere i will consider buying it if it is in good shape
the truck has crank windows
Diesel Dan
Postby VEfreak » Sun Dec 28, 2008 11:52 pm
check the junk yard my friend. Luckly there are doors applenty for these trucks.
I AM ZUES DAMNIT
VEfreak
Postby PapeCAT » Mon Dec 29, 2008 8:53 am
yup anything from any truck d100-w400 will fit. might want a rig that is 1980 + though.
PapeCAT
Postby PToombs » Mon Dec 29, 2008 5:35 pm
Yup, mine was cracked like that. I had over 1/2 a day in fixing it, but I went overkill. I removed the plate inside that the bolts thread into, and built a reinforcing plate to go under the threaded one. I cut and fit it inside, welded the crack inside and out, ground it smooth, welded the plate in, and put the threaded plate back. Lotsa work, but my door is solid.
