2nd Gen Seats
2nd Gen Seats
Postby cedardiesel » Sat Jan 03, 2009 12:15 pm
I have found a set of 98-02 2nd Gen Seats from a Ext Cab would they fit in my 92 Reg. Cab Truck?
90 W250 4x4 5spd pump Ve cranked wide open, BHAF, HX35 with all 2.5" intake piping, and 4" straight piped
92 W250 4x4 5spd P-pumped B1B over B2 are on and now slippy clutch
cedardiesel
Postby cedardiesel » Sat Jan 10, 2009 1:05 pm
i know somebody has to know something about 2nd gen seats in a 1st gen
cedardiesel
Postby MUDDY » Sun Jan 11, 2009 12:20 am
well,,,,,,,,,,,,,,, one of my 92 clubcabs had 2nd gen seats in it and they fit perfect. i bought it that way with those in the front and 95 chevy ext cab rear seats installed into the rear of the club cab.
it was b itchin :grin:
97 D-3500 flatbed dually 385/837
93 D-350 dually
90 W-250
FOR IDAHO EVENTS WATCH
http://www.idahoturbodiesels.com
MUDDY
Postby cedardiesel » Sun Jan 11, 2009 7:25 pm
Thank you Muddy but I got a regular cab thats my concern Does anybody got pictures of the install of 2nd gen seats
cedardiesel
Postby RumbleFish » Sun Jan 11, 2009 8:32 pm
MUDDY wrote:95 chevy ext cab rear seats installed into the rear of the club cab
you got pics of this? ive measured one and thought it would work well.
Postby Richie O » Sun Jan 11, 2009 8:37 pm
Of coarse my 90 gmc beater has no rear seats. Some nuckle head took them out before I got the thing.
Postby MUDDY » Sun Jan 11, 2009 9:49 pm
ya might pm 'BIG DADDY' at www.idahoturbodiesels.com [dont know what he uses for a username here, something different] he would take pics of it and post or cell message.
he is the one i sold it to. i dont have interior shots of that truck. it is the one that now has the rockwells and 53's :grin:
it worked well but of course legroom was a bit tight
93 D-350 dually
90 W-250
MUDDY
Postby IowaCummins » Sat Mar 21, 2009 12:15 am
i just put 40/20/40 2nd gen seats from a 01 in my reg cab 93. ok first off they do fit but that is if 5'5". you cant move them back very much further due to the high back of the seat or you would be sitting straight up and down. mounting them was a bit of a chalange the rear part of the braket slider had to be cut almost all the way up to the slider bar. the front had to have 3 or so inches welded onthe the middle of the truck bracket and the outer braket had to have 2" welded on. the back brakets to mount the seat i had to pound in the sheet metal floor in a few areas. then if you get seats that were in an extended cab truck it will have a cup holder slide out in the rear. cut the rivets off of it. turn it around and aim it towards the front weld or screw it on there and now you have a pull out cup holder for your truck that isnot in the way when you dont need it. mount it offset to the drivers side so you can mount a cb next to it. all under the seat hidden. i can get pics tomoro if i remeber. the look great in the truck and nwo road trips are a little bit more bareable minus the 7" stacks inteh back. lol
IowaCummins
