Cab swap?????
Cab swap?????
Postby pulltilbroke » Sun Jan 11, 2009 12:08 pm
OK I'm gonna be doin a cab swap in the spring and was wondering what differences there are in cabs, my truck is a 90 and I'm gonna be putting an 86 big hump auto cab on.
Are the holes already there for the clutch MC ?
Is there any difference between a Diesel and a gasser cab?
What else should I be aware of before atempting this swap?
I am going to be using my whole wiring harness
This will be my first cab swap with this many wires. "I'm used to workin on mid 60's Chebys"
Postby TRENDZ » Mon Oct 26, 2009 6:03 pm
I just found out that an 86 cab mounted on a 91 frame with a 92 518 automatic trans, has trans tunnel interference. A few wacks with a hammer on the drivers side gives sufficient clearance. I just wish I knew this before painting/rustproofing the cab.
TRENDZ
Postby PToombs » Mon Oct 26, 2009 6:11 pm
A spray can of undercoating will help you out real good! ;)
Postby ahale2772 » Mon Oct 26, 2009 7:48 pm
im doing the same swap in spring, to a 87 gasser cab
Postby PToombs » Tue Oct 27, 2009 5:36 pm
ahale, you might better cut out the hump and swap it on your truck. There's a big difference with a 4x4 or standard truck. A little whack with a hammer won't work on yours.
Postby NOT_A_BLAZER » Thu Jan 07, 2010 7:00 am
Should be a straightforward swap for the cabs if both trucks are a standard cab 2wd auto though,right?
Nick
1991 D250 (5.9 CTD/727/D70) all stock (for the moment)
1987 D100 (225 Slant/904/8.25) future body donor for the '91
1979 Ramcharger (318/727/NP208/D44/9.25) Project Truck
NOT_A_BLAZER
Postby RumbleFish » Thu Jan 07, 2010 1:39 pm
yes
Postby NOT_A_BLAZER » Sat Jan 09, 2010 10:32 am
sweet.
Nick
NOT_A_BLAZER
Postby Mark Nixon » Mon Jan 11, 2010 1:55 pm
Pullit, here's the differences just in YOUR 2 cabs.
The '86 cab has:
No holes under the dash to mount the clutch master bracket.
No hole in the firewall to pass the clutch master cylinder through.
The bulkhead wiring is relocated @ 1-1/2 inches to the driver's side and @ 3/4" DOWN on all mid-'87 and up trucks to facilitate locating the hydraulic master cylinder.
Additionally, you'll need to use your pedals, BOTH of them.
Is your '86 cab the "wide floored" one for 5 speed and/or 4wd?
Re: Cab swap?????
Postby pulltilbroke » Sun Oct 31, 2010 6:48 pm
Well just got home from Mr. Nixons place. Just picked up a nice 92 cab that needs a few minor dings repaired and when I say minor a lot of em you wouldn't see but its Going black so.... . Cab is rust free and will make my cab swap much easier.
