where can i buy the fender flares/molding?
Postby oilcan64 » Sat Mar 07, 2009 5:59 am
HI everyone
I just joined the site b/c a friend of mine , Parker, anyways Im Justin and i just bought a 92 w250- heres my question i was wondering, after seeing several nice looking trucks, how is that there molding looks perfect, do they sell replacement ones anywhere, ill try to list a picture, also ill place a link, b/c i like the two tone but you can't really do it without the molding, it wont look right- so im looking for the plastic fender flares and the black strip that goes from the front fenders over door to the back of the bed?
http://www.youtube.com/watch?v=wEHUK...eature=related
http://www.dieseltruckresource.com/c...ate/1170732845
thanks
Justin :roll: [/list]
1992 - w250 - 5 speed - LE - Reg. cab - 8' bed - minor pump tweaks - srw - ic
KDP & Killer Bolts killed
Saving for body work!
oilcan64
Postby Richie O » Sat Mar 07, 2009 7:33 am
both of your links are junk. No worky.
Postby oilcan64 » Sat Mar 07, 2009 8:11 am
thanks for responding but after looking through the forums i dont think ill put them back on the truck looks just as good with them off
Justin
oilcan64
Postby peobryant » Sun Mar 08, 2009 8:06 pm
I have seen people paint them back to black, and they looked pretty good from the pictures. If you leave the trim off, aren't there holes that will need to be filled?
Postby burnt_servo » Sun Mar 08, 2009 9:19 pm
some of the older vw jetta's ( around '88 to 92 ) use a dark plastic wheel lip / rocker moulding , and i know of many guys that have used black shoe polish to "spiff " them up .
haven't tried , or seen it done to a first gen , but i might give it a try on my '91 w150 this summer .
once you paint them , that is it ..... it's hard to remove the paint later .
if you do a poor job it looks like hell .
and being more of a rubber than a hard plastic i can see paint easily peeling even with the proper flex agents added to the paint .
'93 w250 .... stock ...
burnt_servo
