windows
windows
Postby 1991cummins » Wed May 13, 2009 9:30 pm
i have a friend that has electrical mirrors that wants crank ( :? ???) i have crank and want electric, we want to swap...
are the "window regulators" or tracks the same? cause it looks like to me the only difference is that instead of an electric motor i use a manual crank to turn that gear? am i right? has anybody done the swap before?
and lastly, i know i have a connector for a tach and for overdrive, neither of which i have... so i was curious if i had one stuffed under there for the electric window motors? any help would be great, because im not sure if i want to tackle this...
Derek
1991cummins
Postby redneckroot » Thu May 14, 2009 7:36 am
redneckroot
