I found almost mint 1990 cab BUT ?????
both inside and out
Postby roxxx » Fri Nov 06, 2009 5:24 pm
The cab (1990) doesn't have air conditioning and my truck does will this swap work or will i loose my Air ??
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
Postby TRENDZ » Fri Nov 06, 2009 5:56 pm
I just replaced my 91 cab(air) with a mid 80s cab with no air. The firewall is the same on the pass side where the heater/ A/C box goes. The firewall had minor differences on the drivers side where some of the wiring goes through. Nothing to sweat though.
91 d350 1/2" supply lines, 2nd gen lift pump, regulator, 366, screwed, homebrewed afc pin, linkage mods, ported head, ported ex manifold, 351ve electrically controlled, 3" boost tubes, 2nd gen I/C, 4" ex, goerand
TRENDZ
Postby roxxx » Fri Nov 06, 2009 6:25 pm
Thank you
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
Return to Body
