Cowl Hood??
Cowl Hood??
Postby 92 D/UNIT » Thu Nov 26, 2009 7:54 pm
Are there any companies that make an aftermarket cowl hood for a dodge p/u? Or has anybody retrofitted one from another application?
Brian 92 D 250 250K, A518, pump mods, BHAF, 4X15s, 4" turbo back dual exh, 3200 spring, HTB2 62/12.
SOLD 92 w250 ex cab, 5 spd, 3.54, 320,000, WH1E 14, Fuel pin, pods,shortened 4200 gs, Bhaf, 4" turbo back
388/886
92 D/UNIT
Postby redneckroot » Thu Nov 26, 2009 9:03 pm
http://www.showcars-bodyparts.com/dodgepic.html
I've never ordered from them, but I'd love to have the full tilt front end.
redneckroot
Postby PToombs » Fri Nov 27, 2009 6:25 pm
There's another place too, I can't remember the name of it though. :oops: I'd love a tilt front end, I just can't justify the $750-800 price tag. :cry:
Postby 92 D/UNIT » Fri Nov 27, 2009 7:47 pm
PToombs wrote: I'd love a tilt front end, I just can't justify the $750-800 price tag. :cry:
I agree would be cool, but pricey,
388/886
92 D/UNIT
Postby oldestof11 » Sat Nov 28, 2009 8:54 am
Outta curiosity, but where would you put all the stuff on the front fenders? Also the coolant hoses? I ASSume that the hood doesnt pop up??
Re: Cowl Hood??
Postby 90FIRSTGEN CUMMINS » Mon Feb 15, 2010 8:27 pm
I bought a full tilt frount end for our year trucks from a company called US Body. I am not shure if they still have cowl hoods but they did a few years ago.
1990 W250 Non I/C, Mostly stock,4 inch Ex,Fuel Screw Turned Up a Little, 727TF, 366 spring, BHAF, Borgeson Steering Shaft, Under-bed B & M transmission cooler, head lights now on relays(just added)
90FIRSTGEN CUMMINS
Re: Cowl Hood??
Postby 90FIRSTGEN CUMMINS » Mon Feb 15, 2010 8:28 pm
front end :?
90FIRSTGEN CUMMINS
Re: Cowl Hood??
Postby burnt_servo » Tue Feb 16, 2010 1:06 am
my dad picked up one for my 2002 ( cowl hood ) .
it was actually alot cheaper to get the aftermarket hood than buy a new one from chrysler .
not sure if the same thing applies to the first gen stuff
'93 w250 .... stock ...
burnt_servo
Re: Cowl Hood??
Postby RumbleFish » Tue Feb 16, 2010 12:47 pm
boooo, cowl hoods go on chevys. :thumbdown:
i had a challenger hood on my 91, i got it used but it was also from us body.
Re: Cowl Hood??
Postby cumminz90 » Mon Mar 22, 2010 1:16 pm
another place to look would be truckinfx.com i believe thats the site it has those hoods in steel and fiberglass
1990 D250 sc Cummins: 175 p pumped motor: (400ccs)100 plate, 4k springs, rack plug,Jl machine 5x16 injectors, ad150, cooler tubz, hellman sump, studs, valvesprings, hx35/3b twins, timing 20 *, soon to be built 47rh
GFs: 1993 w250 cc: Normal pump mods, timing to the head, 3200 spring, denny t stage 2, DDP 4 injectors, hx 40, swapped in a rag
1991 w250 rclb: normals pump stuff 3200 spring
cumminz90
