Primer
Primer
Postby TTipswprd » Wed Dec 02, 2009 11:16 am
Does anyone know of a good quality primer in a rattle can? ive got some good stuff but no spray gun and don't really want to lap it on there with a paint brush. any thoughts?
TTipswprd
Postby 1STGENFARMBOY » Wed Dec 02, 2009 11:34 am
Any of the name brand is ok even the cheap stuff works but you need to put several coats on. ;) make shure it's covered very well thats the key.
Postby james-93-12valve » Wed Dec 02, 2009 10:04 pm
at tractor supply they have a oil base metal primer thats good i think its made by valspar not sure ill check tomorow
93 d350 5spd 4inch exhaust to a 6inch tip pump tweaked
james-93-12valve
Postby rmauto1 » Fri Dec 11, 2009 4:23 pm
I have had excellent results with Dupli-color, self etching primer. It lays out really nice, and holds up great.
rmauto1
