fender mounting holes
Postby Farmboy » Wed Dec 09, 2009 11:16 am
On my truck, where the top two front fender bolts are, got pushed back about half an inch to an inch in the accident. Is there a good way to pull that back out, or would it be eisier to cut another piece from a good cab and weld it in mine. I borrowed a picture that i found on here to show you what I am talking about. Maybe if it is not clear enough I will get some pics of my truck when i go home tonight.
Farmboy
Postby diesel freak01 » Wed Dec 09, 2009 12:24 pm
i cant see the pic of what you are talking about (at work) but maybe a slide hammer with a bolt?
1993 d350 ctd drw 2wd auto
diesel freak01
Postby burnt_servo » Wed Dec 09, 2009 6:07 pm
your in luck , my truck on the opposite side has the same problem .
i just asked my dad what would be the easiest way to pull things back into shape ....
what he told me was ,
take some 1/8" plate , cuts 2 holes in it that match where the fender bolts go into the cab .
weld a chunk of chain to the plate .
bolt it into place , and pull in in the opposite direct and angle that it was hit at .
how you pull it straight is only limited by your imagination , but you get the idea.
btw there should be a fair amount of play in the fender , and you can always adjust things with more or less shims , so it doesn't have to overly accurate
'93 w250 .... stock ...
burnt_servo
Postby mprmn08 » Wed Dec 09, 2009 6:08 pm
sounds like you need a bigger BFH :D
mprmn08
Postby PToombs » Wed Dec 09, 2009 6:21 pm
bs has a good idea! ;) You only need to get it close, because you can adjust it some. If you don't get quite enough, you can open up the hole on the fender a little too.
Postby Farmboy » Thu Dec 10, 2009 5:40 am
Thanks these all sound like good ideas. I am going to set the dog box up on there first to see how much it needs to move. and then I think I am going to try the plate deal. I can just park the tractor in front of the truck and put a come-a-long inbetween the two. :wrench:
Farmboy
