by PRINCETON_JAKE » Tue Jan 12, 2010 7:04 pm
Dang thats sweet, I need to find a set of them, aspecially (sp) since i just went through a barb wire fence and lost one mirror.
1992 cummins, 2wd, A518, WH1c, 60mm,12cm housing, fuel screws maxxed, fuel pin turned and ground, 3200rpm spring, big Amsoil air filter, 4" stack, timming bumped, piston lift pump, Bosch 190's, 18" Maxxi Hulk rims, and Nitto Terra Grapplers.
