aftermarket grilles
aftermarket grilles
Postby jwatso8 » Sat Jan 23, 2010 3:03 am
does anyone know where to find an aftermarket grill? thanks
SOLD 92 D250 intake,S300,coolertubz,i/p MAXED,366 spring,Dennyt fuel pin,DDP 4,airdog 100,gauges, 4" d/p w/5" stacks
TRADED IN07 2500 6speed,intake,CFM+,Edge EZ chip,MBRP exhaust,B&W hitch
NEW 2010 3500 6.7L DRW 4x4 CrewCab 4.10 grears
jwatso8
Postby oldestof11 » Sat Jan 23, 2010 7:51 am
When you mean aftermarket, are you talking about a non cracked one or the covers into black area of the grill?
I am going to Ace Hardware and buy either 2 or 4 sheets of the diamond cut, thin sheet metal, cut them to size, and insert them with the existing screws into the black areas.
rbrettctd did something similar.
Re: aftermarket grilles
Postby BobS » Sat Jan 23, 2010 9:55 am
jwatso8 wrote:does anyone know where to find an aftermarket grill? thanks
Maybe the ones on www.rockauto.com ??
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby adam greene » Sat Jan 23, 2010 12:55 pm
you can buy billit grill inserts on ebay
adam greene
