Hood release cable
Hood release cable
Postby cumminz90 » Mon May 24, 2010 3:16 pm
Im having trouble trying to find a hood realse cable new or used anywhere ive looked the ole one frayed and the outer shel is ruined do any of the dodge vehicles interchange such as the vans or am i better off modifiing a newer one to fit on? thanks in advance :)
1990 D250 sc Cummins: 175 p pumped motor: (400ccs)100 plate, 4k springs, rack plug,Jl machine 5x16 injectors, ad150, cooler tubz, hellman sump, studs, valvesprings, hx35/3b twins, timing 20 *, soon to be built 47rh
GFs: 1993 w250 cc: Normal pump mods, timing to the head, 3200 spring, denny t stage 2, DDP 4 injectors, hx 40, swapped in a rag
1991 w250 rclb: normals pump stuff 3200 spring
cumminz90
Re: Hood release cable
Postby SNOOT » Mon May 24, 2010 4:23 pm
Check this link out.. Shows them for $64.00
http://www.moparonlineparts.com/partloc ... eid=214954
1993 W350
SNOOT
Postby cumminz90 » Mon May 24, 2010 4:58 pm
nice just what i was looking for thanks for the link
cumminz90
Postby Billy Boy » Mon May 24, 2010 6:52 pm
This was one of the first issues I ran into when I got my truck. I went to a junkyard, pulled one off of a similar body style gasser (with the latch and all), and it worked. About $4 or $5 iirc...
1989 Dodge D350 Dually, Non I/C
Billy Boy
