SLIDING BACK GLASS
both inside and out
SLIDING BACK GLASS
Postby BEARKILLER » Fri Jun 29, 2007 3:25 am
The #4 truck has a sliding back glass.
The son's truck doesn't and he wants to trade.
I have swapped these rear glasses around in old Chevrolet trucks, several different times.
Does the same method apply to swap the glasses in the Dodge??
I know that to INSTALL, I wrapped a greased string around the rubber seal and pulled the string inside the cab, while someone outside held the glass against the rear.
I don't really remember what I did to get a glass started OUT.
Please walk me through this and refresh my memory.
Thanks.
MY TRUCK = 1985 FORD F-350 2wd, 89 1st.Gen.Cummins,Getrag 5-sp,Dana70 3:55
WIFE'S TRUCK = 1991.5 D-250 I/C, Auto
SON'S TRUCK = 1990 W-250 Getrag
#4 = 1991 D-350 LE Getrag
BEARKILLER
Postby whereswaldo250 » Fri Jun 29, 2007 10:14 am
I would also like to know as well, mines about gone and if anybody knows where to buy a new one let me know. Sorry bearkiller if I hyjacked at all.
1992 Dodge W250 standard cab STRAIGHT PIPED! black 3/4 ton Cummins Turbo Diesel Intercooled, 4x4,148000k, getrag 5 speed, np205 transfercase with PTO, D60 in the front, D70 in the rear posi (4:10 gears), Mods soon to come
whereswaldo250
Postby wannadiesel » Fri Jun 29, 2007 3:12 pm
There's a retainer molding you have to pull out first, then you can just push the glass out.
JC Whitney sells new sliders, I put one from them in my '85. Makes a huge difference in the airflow through the cab.
Best dyno: 408/844
wannadiesel
diesel guru
Postby PToombs » Fri Jun 29, 2007 6:48 pm
wannadiesel wrote:There's a retainer molding you have to pull out first, then you can just push the glass out.
Unless you are hauling hay or something light weight and loose! :shock: Then it ends up in the cab with you! :cry:
Postby wannadiesel » Sat Jun 30, 2007 5:33 am
Very true. If my truck's been parked under a tree, or I've hauled anything loose (like mulch ir chips) I run 'er at 75 mph for a couple miles to clear the bed out before opening the window. :lol:
Best dyno: 408/844
wannadiesel
diesel guru
Return to Body
