heater core bad ?
heater core bad ?
Postby dodge1stgen » Wed Jan 26, 2011 11:10 am
Started the truck this morning and left it run for about an hour to melt the snow off,when i got in it there was anti freeze on the floor.I figure it is the core ,or is there something else it could be.Thanks Eric
93 250 ext cab p pump injectors 2 disk clutch 3'' charger nv 4500 retired
92 350 ext cab 5 spd 366 spring bd injectors hx 35 dana 80 flatbed
92 350 converter built trans bd fuel pin flatbed/dumpbed
dodge1stgen
Re: heater core bad ?
Postby dazedandconfused » Wed Jan 26, 2011 2:52 pm
Sounds like the core to me.
Postby Richie O » Wed Jan 26, 2011 5:43 pm
On the floor inside the cab, or on the floor ( ground )? If its in the truck it could be a leak right at the connection to the heater core. I have seen them actually squirt twords the inside and then drip in the truck. I would bet though it is the core leaking.
