another cab ?
another cab ?
Postby CAJUN 93 » Wed Feb 02, 2011 1:02 pm
i'm getting ready to do carpet in the wife's truck and all the places i check list 2wd or 4wd carpets for the extended cab auto 93. i have in the yard 3 d250 ext cab autos, 1 d350 ext cab 5spd, 1 w350 std cab auto, and a 2wd ramcharger. all are 92-93 models. as best i can tell they all have the same exact cab floor. all have the wide hump, even the ramcharger. what give's? it looks like i need to order the 4wd carpet set even though the truck is 2wd, but i dont want to order the wrong carpet set. any help would be appreciated.
daryl
CAJUN 93
Re: another cab ?
Postby RumbleFish » Wed Feb 02, 2011 1:28 pm
the ramchargers uses the same big hump, 2 or 4wd. as for the pickups, only thing i could think of is that the ext cabs all use the big hump too?
Re: another cab ?
Postby Mark Nixon » Wed Feb 02, 2011 11:38 pm
The short answer is:
If the wife's truck is an extended cab auto, order it for a 4wd.
All of the 1987-1993 extended cabs used the 4wd floor.
Re: another cab ?
Postby ellis93 » Thu Feb 03, 2011 4:41 am
Where are you buying the carpet from?
Re: another cab ?
Postby CAJUN 93 » Thu Feb 03, 2011 7:08 am
i've seen several places but i keep coming back to this one.
http://www.stockinteriors.com/Model.asp ... dge_Carpet
i'm thinking i'll get the heavier carpet and backing and get a set of mats at the same time.
anyone ever use this place?
daryl
CAJUN 93
Re: another cab ?
Postby CAJUN 93 » Thu Feb 03, 2011 7:09 am
btw, thanks for all the input. i sure didn't want to get the wrong thing
daryl
CAJUN 93
Re: another cab ?
Postby ellis93 » Thu Feb 03, 2011 7:19 am
They've pretty good prices there.
Not to over take your tread but by any chance have you came across any floor mats that actually cover the whole floor under the pedals.
