Turn signal lever
Turn signal lever
Postby shiftycapone » Thu Feb 10, 2011 12:57 am
Where does one find a replacement for a 1990? I can only find them for 91+ trucks, as it seems the column changed as well into the model used in the 2nd gens.
Also, anyone know where the hazard light switch is? I cannot find it for the life of me. Anyone else out there with an 89-90 that uses a GM ignition key? Column looks like one out of an 80's chevy, did Dodge just borrow parts from GM? I have looked up other 89-90's cummins and they use the same style column and ignition, just wondering though. As always, thanks!
1990 D250
shiftycapone
Re: Turn signal lever
Postby Richie O » Thu Feb 10, 2011 11:36 am
The 89 and 90 do not use gm column's.
Postby shiftycapone » Thu Feb 10, 2011 11:50 am
Richie O wrote:The 89 and 90 do not use gm column's.
So how about the GM key? Any info on the turn signal lever?
1990 D250
shiftycapone
Postby Richie O » Thu Feb 10, 2011 11:54 am
Both my 89's took a 1 sided dodge key upside down. ( teeth up ) The later trucks had the double sided key. As far as parts, dealer, junk yard I supose.
Postby shiftycapone » Thu Feb 10, 2011 2:30 pm
Richie O wrote:Both my 89's took a 1 sided dodge key upside down. ( teeth up ) The later trucks had the double sided key. As far as parts, dealer, junk yard I supose.
I see. I'm thinking the original owner had a key made by a GM dealer possibly, as the key is one sided. Although the teeth point down in the ignition. Weird.
1990 D250
shiftycapone
Postby bmoeller » Sun Feb 13, 2011 4:09 pm
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby shiftycapone » Wed Feb 16, 2011 7:49 pm
Thanks! Yeah not cheap, found some good stuff at the junkyard out of an 89 gasser, gonna see if the signal lever will work. If not I will deal with my sloppy one for now and keep searching!
1990 D250
shiftycapone
Postby johnnyreb » Sat Mar 05, 2011 5:04 am
just bought a turn signal switch for my 93' at the parts house. autozone and o'reilly's both had it
Almost bone stock 93' CTD. muffler and back half exhaust delete, BHAF, autometer 1600 pyro, VDO 100psi boost gauge, auto meter dual a-pillar gauge pod.
johnnyreb
Postby Begle1 » Sat Apr 09, 2011 2:16 pm
I made my own lever out of a plate of aluminum with an NPT pipe tapped into it.
I put a O-ring around the twisty wiper control arm so it wouldn't rattle against the inside of the pipe. I then put a piece of canvas into the hole and wrapped up the control arm and pipe with hose repair tape.
I went to the junkyard to find a good one... I found about 10 levers, and they were all broken in the same way.
