'91 D-250 Resto Thread
Re: '91 D-250 Resto Thread
Postby ellis93 » Mon Apr 17, 2017 7:07 pm
Postby meby » Tue Apr 18, 2017 9:14 am
Thanks! I have an oreillys near my farm. I'll stop in tonight.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby meby » Fri May 26, 2017 6:12 pm
Air Lift bags are in. I've been hauling some heavier loads and since this truck don't have any overload leafs...
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby PToombs » Sat May 27, 2017 7:06 am
That looks good Matt. Let us know how they work out, or post a pic with a load for a before and after comparison.
Postby meby » Sun May 28, 2017 4:15 am
2400 lbs of concrete mix in the bed. 60 lbs in the air bags. Kept the truck slightly above level. Rode really nice loaded. Kinda rough empty on 45 lbs, but not nearly as bad as dad's 90' that has a 9 leaf pack and has the suspension of a brick.
-Case 530 CK
www.ebyfarmsllc.com
meby
Postby meby » Sun May 28, 2017 5:18 am
By the way...if you install this kit you can save a lot of time by lining up the upper rear bolt hole on the upper bracket to the rivet on the frame. That puts​ the bag almost center of the axle and the bolts clear the stupid​ abs piece. Also use the spacers between the lower bracket and the leaf pack.
-Case 530 CK
www.ebyfarmsllc.com
meby
