1979 Power Wagon CTD Build
Re: 1979 Power Wagon CTD Build
Postby 79Powerwagon » Mon Sep 18, 2017 11:19 am
Also got a moog draglink. The $20 one I put in the donor truck to get it home is wasted.
Kind of a joke there aren't more options for an affordable adjustable draglink.
79Powerwagon
Postby 79Powerwagon » Mon Sep 25, 2017 7:13 am
Steering tuned up and fresh coat of penetrol :)
Last edited by 79Powerwagon on Mon Sep 25, 2017 10:56 am, edited 4 times in total.
79Powerwagon
Postby Philip » Mon Sep 25, 2017 9:40 am
Would you cut the size of the pic's down. I can only see maybe half of a pic at the most. In the second pic all I see is about 2/3's of the front of a a red rusted trailer.
Postby 79Powerwagon » Mon Sep 25, 2017 10:56 am
I would if I knew how.
79Powerwagon
Postby Philip » Mon Sep 25, 2017 11:38 am
79Powerwagon wrote:I would if I knew how.
Windows Paint. Use the resize tool. If your on a smelly phone I have no idea.
Postby 79Powerwagon » Mon Sep 25, 2017 12:04 pm
Using an iPhone so yeah. Beyond me.
Here's a link
https://imgur.com/gallery/lKpS3
79Powerwagon
Postby 79Powerwagon » Mon Sep 25, 2017 5:40 pm
Can't ever get a decent video....but you get the idea
https://youtu.be/t49gt9Z-fnc
79Powerwagon
Postby spencerdiesel » Tue Sep 26, 2017 6:30 pm
Guess I'm still a newb, truck videos get me all excited
Fuel: THD 12 psi piston pump, THD fuel pin, 366 spring, fuel screw 1.75 turn, timing bumped 3/32"
Postby 79Powerwagon » Wed Sep 27, 2017 5:36 pm
Then I'm a newb too.
https://youtu.be/yMZxByTedDM
79Powerwagon
Postby RumbleFish » Mon Oct 09, 2017 10:39 pm
79Powerwagon wrote:Kind of a joke there aren't more options for an affordable adjustable draglink.
Oh but there is. PO of my 93 put a GM steering box (extremely similar to ours) in the 2wd position along with the matching pitman arm, re-tapered the steering arm on the axle for K30 drag link ends, and the result is now a $40 adjustable draglink that I can replace at any parts store. Id post some pics but photobucket, well, you know...
I could've left it stock...but why?
Postby 79Powerwagon » Fri Oct 13, 2017 4:03 pm
79Powerwagon
Postby spencerdiesel » Sun Oct 15, 2017 4:39 pm
Good lord! Did you have fuel screw left?
Postby 79Powerwagon » Mon Oct 16, 2017 4:55 am
Screw has been bottomed out.
I had more pedal left :D
TV linkage is limiting the throttle travel.
79Powerwagon
Postby 79Powerwagon » Sat Feb 17, 2018 9:00 pm
Got a TCS converter from Ofelas which spurred on a full drivetrain rebuild...
Rod/main bearings, gasket set, 60lb springs, pump rebuild, m&h spacer, 205 reseal, firewall sound deadener
Typical winter maintenance :roll:
79Powerwagon
Postby spencerdiesel » Tue Feb 20, 2018 8:54 pm
Think you could get some pics of the tear down and how bearings and such faired with the added powa?
